MacBook Pro stuck on loading screen. Help!
Need help on 2016 Macbook Pro 13” Stuck at the loading screen. I honestly have no idea what happen, although has a few suspicions.
This is the second time it happen. First time was when I put my MacBook down in a room and I believe it was pretty humid. The next day, it won’t turn on. Hence my suspicion.
I used hair dryer to it and left it in a bag with silica gel for a couple of hours. And it works! (Same symptoms, will talk about it in a bit).
But now (I don’t think it was a humid room, but possible), it happened again! The symptoms are as follows:
- Took longer than normal for boot up chime.
- Took longer than normal on user account loading screen (right when you enter a password)
And then stuck at 100% forever. I do however tried silica gel and hair dryer again, neither altered anything.
Tried all the SMC, NVRAM, PRAM reset, none works. tried recovery, safe mode, nope!
I did realize however, on the user loading screen after 100% where it stuck, my MacBook responses to my keyboard! ex: playing music, notifications, and sound.
But screen still stays stuck on loading screen. Decided to try HDMI to test if my screen is broken, not working.
Any helps?
Esta é uma boa pergunta?
5 comentários
Do you have a second Mac? Hopefully you can try connecting between the two via a Thunderbolt cable back to back. What we are going to try first is to log in from the second system can you achieve that? If not let's try restarting the system and this time press the T key to enter into target disk mode, did that work?
por Dan
@danj unfortunately i do not have a second mac
por Asketh
@asketh6 - No friends with one?
por Dan
@danj - no, i am away at the moment for holiday so none at the moment.
por Asketh
Time to visit an Apple Store or authorized service centers being the best where you are now. Otherwise wait until you get home.
por Dan
