iPhone 6 turn off
Hello everyone. I have iphone 6 when i unplug from from power after sometime it turned off and get heated around the front camera. Thank you.
Esta é uma boa pergunta?
It sounds like you may have a defective FCAM module, that is causing excess current draw and shutting down your phone, either because of heat or simply battery drain.
Open up your phone and disconnect the FCAM flex to see if the problem goes away. If it does, then you need to replace the FCAM assembly. If this was following a DIY screen repair and the replacement screen was fully populated, then just put your original FCAM Flex in the replacement screen.
Esta resposta foi útil?
Very well explained! Very nice of you to insert the guide and more information so Mimo can have as much help as possible.
Thanks @iphonegarage.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 36
