Ir para o conteúdo principal
Safari can’t find the server
I recently found an iBook G4 and I put an Airport Card in it to connect to my home wifi. On the Network section there is a green dot next to AirPort. The Mac OS X is 10.3.9. Do I need to upgrade to Leopard before Safari will work? Or what else do I need to do?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Will it connect via an ethernet cable?
por
Yes I can via an ethernet cable but only some sites come up. When sites to come up they aren't complete and no pictures.
por
Adicionar um comentário
1 resposta
You need to use a browser other than Safari. Most web servers these days use secure connections (https) which may be too advanced for Safari to comprehend. If you can upgrade to 10.4 then I’d recommend TenFourFox, otherwise look towards iCab (v4.9 is the latest that’ll run on 10.3).
Esta resposta foi útil?
Pontuação 0
2 comentários:
Can I upgrade to 10.5 then download another Web browser?
por
Yes. I'd still recommend TenFourFox in that case. Be aware that there are different builds of TenFourFox depending on your processor, so be sure to download the correct version for your machine.
por
Adicionar a sua resposta
Ryan Mueller será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 400
