Ir para o conteúdo principal
The Razer Naga Trinity is a gaming mouse made by Razer and powered by Razer Chroma. This device comes with three interchangeable side panels and is compatible with Mac and Windows computers. Model number RZ01-02410100-R3U1.
7 Perguntas Visualizar todos
How to fix numeric panel
Hi,
The problem on my Naga Tirnity is that depending on the light effect that has set the numeric panel it starts to spam some of the buttons. The most problematic effects are Wave, Spectrum Cycling, and some static colours. If i set the numeric panel with a static red, there’s no problem, for example.
Razer support couldn’t help me because i’m from latin america and here there’s no support from Razer.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi,
The problem seems to be linked to Razer Synapse software issue. Since the problem only occurs when other mode/cycles were set through the software. Possible fix is to update Synapse or rollback to the stable Synapse version when everthing is working fine.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
nicosantoro95 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 47
Duração total: 1,405
