Ir para o conteúdo principal
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
20 Perguntas Visualizar todos
Won't turn on after Water Damage
Hello.
I recently received a MacBook Pro (13-inch, 2017, 2 TBT3) with water damage.
I treated all the components for water damage by cleaning with isopropyl alcohol. I also put the board in a heating oven for 1 hour on 175 degrees Celsius.
When i opened the MacBook the components didn’t look to bad to begin with. After thoroughly cleaning them they look like new.
The battery seems to be dead as i can only measure 2-3V on it. If i plug in the charger i measure about 12V on it but even after charging it overnight the battery is still at 2-3V
After all this the MacBook doesn’t show any signs of life. So i am hoping anyone out there has any more tips or tricks i can try.
Is it depended on the battery being fully functional or does the main board definitely have some issues?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I believe that even if the battery doesn’t hold charge it should power up if everything works. I believe the laptop motherboard is probably fried. You could pull the SSD off and try on other Apple computers to make sure its not storage problem.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Total Repairs AS será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 57
