Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Perguntas Visualizar todos
MacBook Pro A1398 Won’t Turn On, No Chime!
So I took my MacBook Pro to Mexico and shortly after returning the mouse began to lag and dance around the screen.
Then after traveling to Dominican with my Macbook it shut down and wouldn’t turn on.
I attempted to take it to a store to fix it but they said they couldn’t do anything and the apple store said it would cost nearly $1,200 to fix it!
Would love any advice as I would really love to get this working again!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
If you don’t like the idea of having it fixed by Apple you basically have three options:
  • Find an indipendent shop in your area that will do the same job as Apple but cheaper.
  • Buy a logic board and replace it yourself. iFixit and other vendors will be happy to sell you one.
  • Find a repair lab where they fix boards at component level. This will likely be the best option if you can find a reputable repairer in your area for a number of reasons, but the ultimate choice is of course yours.
Esta resposta foi útil?
Pontuação 3
If all else fails, don’t go to an Apple Store. Call them directly at 1-800-myapple. Ask for a “Flat Rate” repair. Tell them about the battery. It should ve a tier 2 repair and total costs will run right at $550. If they accept it (no liquid damage or major drops. They will fix any and all problems they find for the price.
The problem was that it wouldn’t boot and it went in as a battery replacement.
I just did this on a 2016 MBP two weeks ago. They ended up replacing the logic board, the display and the bottom cover all for the flat rate. Total time including ground FedEx shipping was 5 days. I now have a 90 days full warranty on it.
Pontuação 3
Adicionar a sua resposta
Selah K será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 649
