Ir para o conteúdo principal
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
Why can't I put in the Propeller on the drone
It like I take off the propellers off because there destroyed. But when I put the new ones it won’t go on please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Propellers you trying to replace are they identical with ones you took out? If they are the same ones and doesn't go easy then you can use little wd40 it will slide in easily.
Esta resposta foi útil?
Pontuação 0
Missing spacer. The propeller sits on a spacer. The spacer connects to the rotating stem. The propeller attaches via the screw. Check your old propeller for the spacer and sore attached.
Pontuação 0
Adicionar a sua resposta
Chris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 425
