Vertical and horizontal lines Bravia KDL 55w828b
Hi everyone! A friend of mine gave me his Sony Bravia because of some problems. When the image is still some vertical lines are visible but when I try watching a video instead of the lines I have a ghosting image. All the problems almost disappear after an hour and the only thing that remains is a slightly flickering horizontal line.
I tried disassembling the frame and pushing on the flex cables all around the screen searching for a faulty connection but nothing happened. What could it be? Should I try taping the flat cables that go inside the t-con? Could it be the t-con itself? Thank you for your time!
Update (01/06/2020)
This is what sits behind the plastic, ler me know if the photos are detailed enough. I think the tcon sits behind everything, so its not visible.
Update (01/06/2020)
This is the tcon
Esta é uma boa pergunta?
