Ir para o conteúdo principal
The third iteration of the 10.1 inch Galaxy Tab tablet.
126 Perguntas Visualizar todos
Galaxy Tab 3 won't charge
Hi,
On attempting to charge my Samsung Galaxy Tab 3 10.1 the battery symbol comes up with the lightning bolt inside it but the whole logo just flashes and doesn’t charge the device.
Does anyone know what is happening here?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi, try a different compatible charger (even connected it to a computer) or a different charger cable
Esta resposta foi útil?
Pontuação 3
Neil Pattison  if the aforementioned answer do es not resolve the issue then it is possible that you need a new battery Samsung Galaxy Tab 3 10.1 Battery Replacement Also, check the port where the charger connects to. Make sure that it is clean and that there are no bend or broken pins etc. It is repalcable as shown in this guide Samsung Galaxy Tab 3 10.1 Charging Port & Microphone Replacement Worst case scenario would be an issue with the power management IC on the motherboard. So let us know what you find out.
Imagem de Samsung Galaxy Tab 3 10.1 Charging Port & Microphone
Guia
Nível de dificuldade:
Moderada
10 - 45 minutes
Imagem de Samsung Galaxy Tab 3 10.1 Battery
Guia
Moderada
10 - 15 minutes
Pontuação 3
Adicionar a sua resposta
Neil Pattison será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 102
