Ir para o conteúdo principal
Line of business laptops originally sold by IBM and then purchased by Lenovo in 2005. Older models (Pre-XX50) have a WiFi whitelist, so wireless card replacement is not as easy as buying a bulk generic card online.
615 Perguntas Visualizar todos
Why is my computer making a high screech and wont boot?
One day I ended up checking the listen to on this device option in setting and it immediately started making a high pitch constant screech from the speakers I shut it off because it wouldnt stop but when I try to turn it on again the noise starts back up and it wont boot it just remains a black screen with the loading signal where the pointer is. It wont go past that or stop screeching. Please help I have no idea what I can do.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
I am not clear about what you did. Was it something to do with the Sound settings?
And when you shut it off did you do this from the Windows "Shut Down" command or did you just hold the power button down until it shut down?
por
S Speckles what exact model is your Thinkpad?
por
Adicionar um comentário
1 resposta
When receiving the black screen, the Windows shell has been corrupted, damaged or permissions changed, and the system cannot load. The issue can also be caused by a corrupted video graphics driver. If this is a software issue, it can be fixed without any major changes.
If you can’t log in Windows because of the black screen, you must boot your Windows into Safe Mode first.
If the problem does not happen in Safe Mode, then you will know that default settings and basic device drivers are not causing the issue.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
S Speckles será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,415
