Ir para o conteúdo principal
Originally known as the Pathfinder Armada, the Armada was designed (in 2001 by Diane Allen) for the North American market and introduced in 2003 for the 2004 model year.
6 Perguntas Visualizar todos
Why does my car sound like it's going to stall while idleing?
2004 Armada. Just had starter replaced. Now car sounds like it's going to stall while idleing in drive. Service engine soon light went on and code was for misfire. Had all spark plugs replaced and tune up. It stopped doing it for a couple days. Now it's doing it again and service engine soon light is back on. What can be causing this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
The problem could be the fuel pump.
Have it checked, pressure should read 51lbs.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you. We'll see if that's what it is. My dad was thinking maybe it might need a fuel injector flush?
por
Adicionar a sua resposta
Kristy Francis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 169
