Ir para o conteúdo principal
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Perguntas Visualizar todos
Trackpad and keyboard not functioning after replacing parts
Added 31/12
Coconut Battery
Hi all,
I got hold of a A1502 Mid 2014 Macbook Pro Retuna where the keyboard and trackpad wasnt working.
I’ve replaced the battery and trackpad assembly (with new flex cable), SMC, PRAM reset with fresh OS, but still doesn’t work.
Oddly though, if I hold down Option CTRL Shift and the power button, I can see that this resets the SMC as the light on the charger changes colour. But when the mac is up and running, it’s not working. Odd.
Can’t see any marks of water damage, or know if anything is shorting but not sure how to test either. Keyboard illuminates.
Thanks,
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Does the onboard diagnostics run without problems or error?
Restart your system and press the D key to enter into it.
por
Hi Dan,
I can get into diagnostic with external keyboard, in the diagnostic it doesn't work still and comes back with the error;
There may be an issue with the trackpad
Reference code NDR001
There may be an issue with the keyboard
Reference code NDK001
Also to add I get the error "battery needs service PPT004" but I don't get any errors at all on the OS itself.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Lets give this a try: Disconnect both the MagSafe charger and battery (no power at all) now press and hold the power button for a good minute to fully discharge the logic board. Now carefully plug in the MagSafe charger the system should spontaneously restart, is the keyboard and trackpad now working?
If not we need to look deeper at the logic board connections. Take some detailed pics of the connectors (in focus and not blurry) Use a tripod and defused lighting, post them here for me to see Adicionar imagens a uma pergunta já existente
Update (12/29/2019)
Here’s a sets of image which shows a good connector and the latch which appears to have been removed from your keyboard and trackpad logic board connectors (make sure you zoom on them to see).
Properly set
Folding the latch up
Latch in the up position
So… At this point you’ll need to find the latches and carefully snap them back in. Or if they are missing you’ll need to find a junker to pull them off, or get a set of new connectors to then remove the latches from to save your logic board.
Esta resposta foi útil?
Pontuação 2
18 comentários:
Thank you Dan,
I have tried what you suggested and that hasn't worked. I have uploaded photos to the original post, I hope these are suffice.
Thanks,
por
Where are your pictures??
por
Sorry Dan, forgot to attach them to the original post! Now on there.
por
Only needed a tight set on the Keyboard & Trackpad connectors.
While a bit difficult to tell it looks like the connector clamps are missing! Look at the Update above.
por
Hi Dan, they're definitely there as the flex cable is 'clamped' in.
por
Exibir mais 13 comentários
Adicionar a sua resposta
Craig Davies será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 241
