iPad 5 Not turning on Tristar?
A client has dropped a iPad 5 off in good condition for repair.
The iPad is not turning on.
I’ve hooked the iPad up to my amp tester with .06 draw as the result.
I connected to iTunes to test if the computer see’s the iPad.
The charge port feels extremely loose however this has never been a problem.
I have removed the board testing the battery which was approx 3.72V
I have charged the battery to 3.82V, still not turning on.
I have fitted a known good battery (3.9V) still no luck.
I have reconnected to iTunes to rule out LCD, computer still does not see the device.
The amp meter now goes directly to 0.46A when power button is pressed.
I have just found out it was connect to a in car charger - taken off when client made it home - plugged into normal charging conditions - iPad dead in the morning.
Car charging is very common on this iPad.
Tristar change out?
Thanks
Esta é uma boa pergunta?
