Failed: unable to complete Touch ID setup
Screen replaced but the home button lost all functionality. It is the original equipment from the original iPhone 8. Help?
Esta é uma boa pergunta?
You would need to check your home button flex cable first, the one that is attached to the screen. Look under a magnifying glass to see if there is a slight tear.
If it is not the flex cable it will be a component on the home button assembly. This would require a reputable repair shop to fix the problem. The only other solution would be a screen replacement by apple.
Esta resposta foi útil?
The home button may be damaged, use a microscope or something to see if there is any visible damage (such as a tear) in the flex cable. Also make sure that everything was fully connected and “clicked” into place.
If it is damaged, then your only other option is a screen replacement by Apple, as every individual home button is paired to each device.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 95
