Sony kd65xe9005 gets pixelated screen and then turns off, unable to tu
My sony kd65-xe9005 started acting up couple of days ago. After it is on for a while (from a couple of minutes to 4 hours) the screen gets pixelated (see picture) and frozen. The sound continues to play for couple more minutes then the TV goes completely off and is not responding to anything any more. The LED indicator light below, is not responding either. If I unplug it and plug it in again it does not respond. However, if I unplug it and keep it unplugged for a couple of hours (very hard to determine exactly how much, usually over the night) after I plug it in again it starts up again (it doesn't always start up at first, but after a couple of try with plugin and unplug in and pressing power button).
The color lines seem to correspond to the last picture before freezing, but hard to say, once they are on, they are static.
I suspect it has something to do with heating, because after moving it closer to the window and opening it, the TV keep working way longer (couple of hours as opposed to minutes) before it froze. I have tried opening the back and checking the capacitors everything seems ok, also I could touch all components, no-one was too hot to touch.
I also tried unplugin couple of cables (circled on the image) and the screen went from frozen, to the cycling of RGB colors as seen on the last image.
If I unplug these cables the RGB screen comes on (the picture unfreezes), after plugging them in again, it goes back to frozen screen. The RGB screen starts cycling.
Even when TV freezes, the led indicator on the middle board stays green, so I have a feeling it has nothing to do with the power supply.
Anyone knows what the problem might be or how to fix it? Any idea what I can do to exactly pinpoint the faulty component?
Here is the link to the images: ++https://imgur.com/a/pA7ZJG2++
Esta é uma boa pergunta?
