My fridge has stopped producing ice
Hi, my fridge freezer has stopped producing ice. Water is still dispensing and the ice tray is rotating and trying to dump ice - problem is there is no ice to dump!
My freezer is set at -15 so I am not too sure what the problem is?
Esta é uma boa pergunta?
6 comentários
Hi,
What is the make and model number of the refrigerator?
Is that -15 deg F or -15 deg C?
Normally freezers are set for 0 F or -18 C and refrigerators are set for 37 F or 3 C
Have you checked the temp in the freezer with a thermometer to verify what the temp is actually is? (check the temp in the refrigerator section as well)
por jayeff
-15 celcius. Its a kenwood ksbsdix16
I got a hairdryer on the tray and some ice was there the next day. Not a lot though and nothing since
por SG1
Hi,
Is there any water flowing into the ice maker?
Don't know your model but usually there is a sensor or lever that operates to allow water to enter the ice maker and be frozen.
The ice maker may also have a test button that when pressed should dispense the ice (if any) and then refill the ice maker with water
por jayeff
No water is entering the ice maker...
There is a ice on/off button but when I press it I can't hear anything.
por SG1
Please give us your exact model number so we can give you a better answer.
por mayer
Exibir mais 1 comentário
