Ir para o conteúdo principal
Why doesn't my ipod nano want to turn on?
I charged my ipod nano and it was working fine until now it doesn't seem to be wanting to turn on. The hold switch isn't on and I am trying to turn it on by pressing any keys but it doesn't turn on. What can I do. :(
Esta é uma boa pergunta?
Pontuação 13
2 comentários
Yea! It worked. Thanks.
por
What works? I can't get mine to turn on either Model: A1320. It's been charging now more than 12 hours! :( I need it for the road trip im taking today! :(
Please help!
por
Adicionar um comentário
9 respostas
Pergunta mais útil
1. Try resetting it by: holding in both the menu and center buttons for 10 seconds until you see the apple logo.
2. If that doesn't work, try restoring it with iTunes.
3. If iTunes recognizes it, but you still can't see anything on the screen, then I'd guess it's a bad LCD screen.
4. If you can't even get iTunes to recognize it, it is probably a bad motherboard.
Esta resposta foi útil?
Pontuação 10
2 comentários:
I didn't ask anything, but just reading this answer, mi iPod works again! Thanks a lot!!! :)
por
Worked for me, too!
por
Charge your iPod by COMPUTER not iHome.
Then click the center button.
Pontuação 2
What if your iPod frezzes while u wactching your recored videos
Pontuação 0
1 comentário:
This appears to be a new question. Please click on this link: http://www.ifixit.com/Answers
and then hit the Questions box in the upper right hand corner and ask again.
por
ur ipod sucks.
Pontuação 0
My Ipod nano 5th generation has done the same thing. All of a sudden it doesn't turn on at all. Could this also possibly be because of the battery coming unplugged on the inside or the battery becoming jarred or knocked loose? Like I said, it was working perfectly fine before.
Pontuação 0
Hi,
I had the same problem with my Nano. However after many suggested attempts to start it up, I finally worked it out. I connected it to my laptop with the white cord, pressed menu button for about 20 seconds and finally it responded. It wasn't the music that was important because Itunes have stored all of my music. It was the short videos of my dear little granddaughter whom I have no more, that was most important to me. If the motherboard hasn't failed, and if it is just a case of having not used your old ipod for a long time (because you have probably bought a new one, or an IPhone) connect it to your computer. Wait until you see the Apple Logo, press onto the Menu button for about 20 seconds, and hopefully it will respond.
Pontuação 0
1 comentário:
thank you. I tried your remedy and success! Merci
por
nano wont turn on and lock is off
Pontuação 0
how do I turn it on the lock is off and it has a check mark and ok to conect why won,t it come on
Pontuação 0
every time I try to turn it on, it shows the apple sign but is not coming on...... can anyone help?
Pontuação 0
Adicionar a sua resposta
Soap será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 49
Ao todo: 29,405
