MacBook shuts down randomly
Hello
Since a month my MacBook shuts down randomly. It doesn’t matter if it’s on battery power or on mains. Sometimes I get the screen saying it shut down because of a problem, but often it just stops working, but the keyboard is still lit up and when pressing a button it does make a noise.
I have checked the battery with CoconutBattery, I’ve done a SMC reset, PRAM reset, checked the harddrive. All fine. This gives me the impression I have a faulty Logic Board, but before I go out and swap that, I want to check if that’s really the problem. I’m just guessing it’s a broken GPU.
I’ve added two error messages I’ve got. Thanks in advance!
Esta é uma boa pergunta?
3 comentários
Has it had an accident with water? What other history can you add? Would need to be seen by a mac repair specialist depending on where you are I can give you the name of at least one mail in repair company.
por Zerocool278
Condensation maybe since it's seen quite some use in different temperatures and humidities. Few bumps here and there.
Screen is new, battery is new and the harddrive is upgraded from 256 to 512. Although this all happened more than half a year ago. Battery was the latest swap.
I am located in Brussels, Belgium.
por steven
check if your laptop is overheating
por SHIHAM IFTHIKAR
