Lightning port bent, iPhone not charging.
My iPhone 8 is not charging. I noticed that the outer housing of the lightning port has bent. I have got the lightning port inside replaced , but the phone still doesn’t charge.
Esta é uma boa pergunta?
You’ll need to either replace or rework the housing in order to get that working again, I imagine the cable isn’t connecting with the pins inside.
You can just use a wireless charger though…
Esta resposta foi útil?
I think you can getaway with just replacing the Lightning connector iPhone 8 Lightning Connector Assembly and here's the guide iPhone 8 Lightning Connector Assembly Replacement and reshaping the case a bit.
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 2,365
