Ir para o conteúdo principal
XS Max Face ID not working after display change
I have a XS Max that had cracked display. Display was cracked on the top so that is blocked the projector in the right part of the notch. Crack was right in the middle of the sensor yellow thing. I installed new display yesterday and carefully made sure every part of the assembly inside the phone is not broken and moved the sensor part form old display to the new one. Face ID is still not working.
Proximity sensor works, ambient light sensor works, speaker works, front camera works. When face ID is tried to initialise phone says move phone up/down. And little red light is on in the left part of the notch when this happens
Only changed part is the display. The display data has not been transferred to the new display so it is missing true tone now.
Any ideas?
I already did a hard reset and the normal SW things.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Open the front camera and take a self-portrait, check if the background is blurred. There might be flex cable broken.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Sorry for the lateness of my reply. The phone in question is in use daily in my family. I got hold of the phone and tried taking selfie. It focuses nicely to the person and background is a little blurred. Looks fine to me. On the other hand I am not sure what I should be looking for
por
Then you should follow the FACE ID troubleshooting process here:Why Face ID Not Working After Repair
por
Adicionar a sua resposta
teemupa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 307
