Ir para o conteúdo principal
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
500 Perguntas Visualizar todos
Won't agitate or spin on a normal cycle but will on drain and spin
Washer fills with water and won’t agitate or spin then stops and shows OL code. But if i run the drain and spin it does drain and spins the clothes really well. i have replaced the control panel back when they were recalled and once since then. What should I be checking?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If your Kenmore 110 Series Washing Machine refuses to spin or agitate during the wash cycle, see the Kenmore 110 Series Washing Machine Doesn’t Spin or Agitate problem page for possible causes and solutions.
Was it doing the same thing before when you replaced the control panel?
Can you give us a link to the recall? They may have just replaced the part with the same defective one.
How long have you had it? What is the exact model number? You are covered by a lemon law according to where you live.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Barbara Templeton será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 290
