Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
783 Perguntas Visualizar todos
Why won't my system menu show up?
I turned off my ps3 and went away for a night. I get back, I plug it back in and the system started up and after the "ps3" logo disappeared, the sparkly floaty wave just stays there and it won't go to the system menu and my controllers won't connect.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
I have this problem. When PS3 boots up it says ps3 and photosensitive epilipsey then it lags!! I am so worried!!
por
Adicionar um comentário
1 resposta
Solução escolhida
My Answer To Another Question
Boot the system to the recovery menu, and restore it manually. However, there's a chance that all data on the system will get wiped, so keep that in mind. Boot it to the recovery menu by turning it off, then holding the power button down until it has beeped three times, and shut down. Then hold the power button down again until it beeps twice and then double-beeps. A message should come up on the screen telling you to connect a controller with a USB cable. Do so, then select "Restore Default Settings." When the process completes, reboot the console, then boot it to the recovery menu again and select "Restore File System." Reboot it and boot it to the recovery menu one last time, and select "Rebuild Database." Reboot the console, and see if it boots to the XMB (Home Screen)
EDIT:
The Recovery Menu Will Look Like This:
Esta resposta foi útil?
Pontuação 3
9 comentários:
Will that delete my game data and downloaded content?
por
It has the potential too, I've never used it on a console with any data on the hard drive, so I'm not sure. Before you try that, just use the "System Update" feature of the menu, and reinstall the system software. That won't delete any of your data.
por
The problem is I can't go to the menu.
por
My model is a 80 gb ps3 preowned from gamestop.
por
Can you get to the recovery menu that I talked about in my answer? You need to do the system update from there.
por
Exibir mais 4 comentários
Adicionar a sua resposta
Nicholas Villarreal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 6,892
