Ir para o conteúdo principal
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
78 Perguntas Visualizar todos
hello can I fix vertical line 4 inch going from top to bottom?
I replaced logic board because I thought it caused problem but please look at the pictures
there is 4 inch line going from top to bottom is it LCD or connector cables inside?
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
just replaced T-CONE did not work, still same strap 4 inch going from top to bottom
need help
por
I am thinking may it be video cable connector?
por
need help, T-Con board was replaced and same nothing changed
por
Adicionar um comentário
1 resposta
This looks like a messed up T-CON board issue which is on the backside of the LDC panel. Here’s the P/N for the full display Apple P/N 661-5542. Here’s one source 661-5542 Apple LCD Display for 27" LED Cinema Display. I haven’t used them let so let us know if you have any issues.
Esta resposta foi útil?
Pontuação 0
1 comentário:
thank you ! I will buy it and replace
por
Adicionar a sua resposta
Michael Niedzwiadek será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 78
