Ir para o conteúdo principal
{A1989 / EMC3214}—Released in July 2018, the 13" MacBook Pro features quad-core i5 and i7 processors and Intel Iris Plus integrated graphics.
198 Perguntas Visualizar todos
Why is there a blue vertical column on my display.
This morning when I turned on my Mac I noticed a blue verticle column in the 2/4 of my display (the far left being the 1/4). I saw that depending on the orientation of my screen the column would either go away are the whole screen would go black.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Can you post a vid or pics showing us what you see Adicionar imagens a uma pergunta já existente
por
@danj Yea for sure!
por
Adicionar um comentário
2 respostas
Solução escolhida
Not good ;-{
The ribbon cable between the T-CON board to your display assembly has a bad line.
This is a similar issue to the The Design Flaw Behind MacBook Pro’s “Stage Light” Effect problem Apple had. Here the ribbon cable likely got damaged from a bang hitting the black clutch cover which then compressed against the cable damaging it.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Would it be best to send it to Apple to repair, or should I fix it at home?
por
If you still have AppleCare I would let Apple deal with it. Don't wait as you don't want it to expire on you.
If you have AppleCare+ service contract they might charge you (at a reduced price) for the needed part (new display assembly).
por
Can someone help me? My laptop fell and it showed this:
Pontuação 0
1 comentário:
[image|22t32837] I dont know how this happend
por
Adicionar a sua resposta
Sami Tayfour será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 25
Duração total: 2,821
