Ir para o conteúdo principal
This guide will enable you to be able to repair any issue with your PowerBeats3 Wireless Earphones
39 Perguntas Visualizar todos
they said the battery is ok, but I need to the machine near the volume
The battery won’t charge, sometime it’s charging but it won’t last long when i use it only less then a hour
The repair shop said the battery is fine, but i need to change the machine near the volume button?
what should i do ?
at repairing shop they trying to to fix by replacing the machine with the fake one but i refused and choose to wait the better solution
Please you have any solution or the trusted shop to fix it in Jakarta (indonesia)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Oman Muji all of this “The battery won’t charge, sometime it’s charging but it won’t last long when i use it only less then a hour” would make me replace the battery no matter what the repair shop says. I wondered how they tested the battery since it will require a load to show how long it will last. A simple things to do would be to use a USB ammeter when you charge and see how many amps it draws. If it does draw then it is not anything else but the battery. Start with that first.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Oman Muji será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 43
