MacBook 15 2012 super slow even on usb
Hi everybody!
I’ve got a 15” MacBook Pro Mid 2012 that is gonna drive me crazy.
It runs super slow and can’t load OS. It also can’t load bootable USB installer (El Capitan, Sierra or High Sierra ). Sometimes when you let it load for 20 minutes can show installer menu or load OS from HDD but mouse move slow and anything works. It runs perfecly from ubuntu USB.
It runs Apple hardware test without any trouble (here the mouse move quickly and everything respond fine) that give this: 4HDD/11/40000000: SATA (0,0)
So I was thinking about bad SATA cable or HDD but why it can’t load from USB?
After I added a SSD and the SATA cable, putting the SSD in the Optical bay and nothing changes.
Same issues with or whitout (brand new) battery.
I think that I have a NVDIA GPU problem (it can explains good work under linux ) so I remove nvdia kext from extensions in single user mode. Nothing changed, really slow everywhere. So i put kext back in place and now loading bar stuck at start without load anything. linux still works perfectly.
Fun fact: After changing SATA cable and HDD apple hardware test always show same error.
Last idea that I got is that maybe the NVDIA GPU is the problem and I have to permanently shut it off removing some resistors under the power lines but it’s really out of my competences find out what it can be right one.
Thank to anyone can help
Esta é uma boa pergunta?
first update, removed again nvida kext files and computer turn on in a second, but a lot of glitches on the screen and backlight regulation doesn't work anymore
por Paolo Cadeddu
