Ir para o conteúdo principal
Charged, Connects the Disconnects on Contact
My BeatsX will fully charge, and if held in the right position will connect. However, as soon as the wire by the charging port moves, it disconnects from the phone/shuts off. It seems as though there’s a short in the chord. How can I fix this? Do you guys know places near Cincinnati that would work on them? Thanks!
DW
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sadly, there is little you can do as any surgery will kill the patient!
While you could cut the case off to gain access to the wires to hopefully patch them, you won’t be able to reseal things to the point it will hold up very long.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
David Walker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 72
