Ir para o conteúdo principal
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
113 Perguntas Visualizar todos
Is my power supply dead?
Initially noticed morning after a lightning storm - iMac worked fine prior to this.
First 3 diagnostic LED's are lit, but display back-light doesn't turn on. There's also no start up chime sound, but hdd seems to spool up, and white LED is on.
No visible signs of damage to power supply, but want to confirm output voltages. Are ps outputs +24v & +12v only?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
LED #4
Indicates that the computer and the LCD display panel are communicating. This LED will be • ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Contact your insurance agent. I've written many insurance reports on lightning hit machines. They usually end up getting replaced with a new machine because the hit can weaken so many things.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Thanks for the reply - didn't know what the 4th LED meant. Think it's worth trying an external display?
por
You can give that a shot but I don't think it's generating a video signal.
por
Going to test ps output voltage & also try external display, as they're inexpensive to do.
I'm also following up with the insurance agent, but how do they confirm the lightning damage?
por
I have exact same problem on same machine. I also notice that HD is not spinning at all on startup. Did you manage to get this solved? I do suspect PSU in my case, but I was not able to find any pinout for PSU voltages for this machine.
Pontuação 0
Adicionar a sua resposta
Larry Craig será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,513
