Bluetooth WiFi Don’t work
My Bluetooth and WiFi stopped working on my iPhone X
Can’t slide WiFi on and Bluetooth gear keeps cycling
already reset all settings and stored phone back to factory
Esta é uma boa pergunta?
Unfortunately there is no quick fix for this. If you cannot slide Wi-Fi on it means you have a board problem.
The board will have to be split and the Wi-Fi chip will have to be tested to see if it is getting power. That will determine if the Wi-Fi chip needs to be removed and repaired, replaced or whether there is another component damaged, stopping the Wi-Fi from getting power.
This repair is extremely difficult if the Wi-Fi chip needs to be replaced you will have to remove the NAND and unbind the Wi-Fi Address and put back on.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 172
