Can't install new drive
I followed tutorial to replace broken HD ... but after doing all steps I couldn't remove top.
I tried to lift top (under keyboard), but it's seems something that obstruct this-
Esta é uma boa pergunta?
Pontuação
0
Please list the guide you are using. We need to insure you are using the correct guide, please give us the last three figures of your serial number (usually on the side wall in your battery compartment). Also why do you think the hard drive has failed?
por mayer
I tried this tutorial
PowerBook G4 Aluminum 12" 867 MHz Hard Drive Replacement
por Fernando
Did you remove the black screw in the ram compartment ?
por lemerise
That helds the keyboard
por remacberlin
That's the guide for the 867 MHz machine. Which machine do you have? If you can't tell look on the side wall in the battery compartment.
por mayer
Exibir mais 1 comentário
