Ir para o conteúdo principal
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Perguntas Visualizar todos
Why isn't my MacBook booting?
I erased my last HDD using Find My iPhone but I’ve replaced my SATA cable and HDD(The HDD has the OS installed on it) but it still just boots to show me the question mark file icon. What is wrong with this Macbook?
Esta é uma boa pergunta?
Pontuação 0
7 comentários
It’s actually a late 2009 MacBook
por
And I’ve tried the keys but the os may be the problem
por
@joyouscaribou48 - I've altered it to the other model the OS is the same.
por
So if I get say a Sierra bootable usb stick would that work?
por
Exibir mais 2 comentários
Adicionar um comentário
1 resposta
Pergunta mais útil
Restart your system and this time press the Option key that will allow you to access the Startup manager your drive with the OS on it should not be visible. Select it and you should be able to startup.
Reference: Mac startup key combinations
If that fails they you maybe running the wrong OS for your system, the A1342 MacBooks The tightest you can bo to is macOS High Sierra 10.13.x. Frankly I recommend sticking with macOS Sierra 10.12.x as High Sierra has some issues running on SATA based systems.
Update (10/11/2019)
At this point you’ve got a different issue! Either the keyboard connection to the logic board is not making contact or your logic board its self has an issue.
Plug in a USB keyboard (ideally an Apple one) Try using it to gain access to the Startup keys (Option key is what I would start with) If that fails you’ve got a deeper issue.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Joshua Rivera será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 25
