Logic Board Reflow Question
Long story short a buddy of mine spilt a few drops of water on his Macbook Pro and it got on the logic board, hence making the computer not work.
I am very experienced reflowing electronics like Xbox 360s and PS3's. I have seen some a few videos of reflowing a Macbook Pro and it looks similar.
My question is: Is a SLIGHTY water damaged logic board completely fried? Or would a properly done reflow of the logic board fix it?
I know there are tons of things that would effect it but i'm just wondering if there is any hope, or if I should not even waste my time. Thanks :)
Esta é uma boa pergunta?
2 comentários
Would it be visually obvious which components were shorted? If so would it be possible to replace just the shorted components?
por tylr6024
If it is water damage you need to fix, then use 100% alcohol and go over the whole board. I fixed many water damaged phones by fully submerging the logic board and gently rubbing the board. Make sure if you fully submerge you are only submerging the logic board and nothing else such as hard disk etc. Be carefull when you rub because depending on corosion you can remove resistors. See if you can find any corrosion and thats where I would start first.
por crivasevo87
