Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
Logic board swap problems with severe overheating
Hello, I have recently had to buy a new logic board for my 2011 MBP A1278 i7 . I decided to try a risky upgrade by buying a 2012 A1278 i7 logic board and putting it into the 2011 body. I researched it and I knew the board would fit . I am using all existing components from the 2011 i.e heatsinks, fan. Now my problem is the machine over heats to the point of shutting down and giving me three beeps . This happens very very fast . I had to install a fan controller to ramp the fans to max speed so I can use the laptop for simple tasks as watching YouTube. The internal fans seem to not pick up speed on their own and the CPU temps just go through the roof .
My question is , is there any different between the models components like the heatsink or fan ? Would buying a 2012 heatsink and fan fix the problem? Or is there anything else I can do to fix the situation? After rebuilding the computer (I had to replace the LCD also) the webcam does not work and I read somewhere that there is a sensor on it or something ? Any help would be amazing as I am very close to setting the macbook on fire.
Stephen
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
The three beeps usually indicates a RAM issue. You probably installed the old RAM into the new board and it takes a faster RAM. Start with that. Replace the heat sink and thermal paste (sometimes they leak.)
If you upgraded the hard drive change out to the new hard drive/IR cable.
Esta resposta foi útil?
Pontuação 1
The 2012 board has a different heatsink, can’t figure out how you managed to use the 2011 one on that new board but that’s where your problem comes from, more than likely.
Pontuação 1
Adicionar a sua resposta
Daly será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 80
