Ir para o conteúdo principal
The Dremel 4000 is a variable speed rotary device. It is compatible with with all Dremel rotary accessories.
17 Perguntas Visualizar todos
Dramel 4300 rotary tool 120v
I placed my tool into a 220v socket yet it takes in 120v and it stop working any help on how to replace the Electrical Assembly Replacement unit for the dramel 4300 Rotary tool and where i can find an Electrical Assembly Replacement for the Dramel Rotary Tool
i have used the picture for the Dramel 4000 becouse the admin seems not to have Dramel 4300 in the drop down
thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
You probably burned out the motor when you plugged it into a 240V outlet How did you manage to do that? normally the plugs are not compatible.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Could be in a foreign country that uses universal outlets? I am an American Vet living in the Philippines and I changed some of my outlets to accepts everything, I also have a commercial grade transformer for 100 and 120 while local voltage is 220. locally they do not have a third ground connector and also do not have the wide spade (polorized) connector as the USA does. Not sure how simple the dremel plug may be? I also believe that there could be 220 in the USA but the OP is saying 240 so I believe this is not in the USA.......
I recommend to open the tool, see if there is a possible fuse, if not, then replace the entire unit, by the time you get a replacement part, if available, and your time to change it, you will not save much money in the end.
por
Adicionar a sua resposta
Brighton Albert será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 785
