Will using parts of gt i9500 work in i9505
I bought a new logic board of s4 gt i9505 with its front and middle housing and want to use other components from gt i9500 will this work?
Esta é uma boa pergunta?
Hi @desai9999
With there being different parts needed for each model of the Samsung S4, there is a small chance that the parts from both phones will be compatible. Looking up both models, it looks like the antennas and network compatibility is the same, but the chip sets are different. This is because the i9500 is the international version and the i9505 is the budget version.
If you do decide to mix parts from both models, I suggest you test every feature using the built in *#0*# diagnostic feature.
Esta resposta foi útil?
While looking on internet for this same, I came across and article wich said that the main camera of gt i9500 will work only for that specific version and i9505 works with several others, Is this same with other components.
I also found that this both models use the same same antenna .
Ir and rest sensors on up front and top.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 208
