How do I measure output voltages at Tristar?
I am trying to figure out why I can get the voltage readouts from VCC Main and Batt VCC, but not other lines, even when VCC main is the supply for that IC. For example, Chestnut is supplied by VCC Main, but when I try to measure the 6v Boost at C329, I get no voltage?
What is going on here and how do I measure outputs, please give an example such as chestnut or tristar adn how you would go about measuring outputs.
Esta pergunta é pertinente?
Have you got your screen connected when checking 6v Boost?
por Chris Stables
