Ir para o conteúdo principal
Swapping Drives | Bookmarks Move via Migration Assistant
I got a friend who’s iMac’s screen “died”, basically it stays black and from what i can tell, something is wrong with the logic board. He has a second iMac of the same model. I swapped the screen figuring out that the screen itself is not the problem. We decided to just move the data over to the other iMac.
Problem is, he has already done the Migration Assistant but he is missing his bookmarks that he saved on Opera web browser. Does Migration Assistant successfully grabs Opera profiles containing the bookmarks or do you have to export it and then import it or transfer using Terminal to access hidden files?
Or should I just swap the hard drives? I know for Windows this is generally a bad idea even if they are running the same hardware but what about for Mac?
Thanks for anyones help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
You need to Migrate everything, APPs , Data & User
Esta resposta foi útil?
Pontuação 3
2 comentários:
Does Migration assistant move over bookmarks from other browsers like Opera? It appears it does for Safari and Google Chrome but the old version of Opera didn't allow you to export bookmarks without extensions.
por
It will! But, you need to to a full backup (TimeMachine) or directly connect your two systems in target disk mode and do a full restore.
por
Adicionar a sua resposta
Shilo Acebedo-Moore será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 39
