Why is the blue stuff on my laptop keeps moving
the blue stuff keeps moving all over the laptop as seen in the attached picture . what can i do? .
Esta é uma boa pergunta?
Open it up and inspect your battery for swelling. Pressure from a swollen battery on the bottom of the track pad can cause this type of erratic behavior. It can also be caused by a virus.
In the case of a virus, start up in Safe Mode by holding down the Shift key on start up and see if the issue persists,
Substituição da bateria do MacBook Pro 13" Monobloco do final de 2011
Esta resposta foi útil?
the issue persist while in safe mode and is worse. the battery is not swollen
@ayobola - Your trackpad or your keyboards arrow keys are jammed. One is sending a signal to move to the right and then it goes down to the next row and onwards...
@danj what can i do to the trackpad
I would first see if taking it out and clean the edge of the case and the edge of the trackpad with a very slightly damp paper towel with isopropyl alcohol (on the dry side!) You don't want it wet as the wicking action of the layers of the trackpad will be damaged just enough to clean off the surface. If that failed I would replace it.
MacBook Pro 13" Unibody Late 2011 Trackpad Replacement and here's the needed part MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
You could also have a bad key in the keyboard, so don't assume the trackpad is the issue. In either case a liquid spill or using a spray cleaner directly sprayed on the trackpad or keyboard could have dripped in as well damaging it or the keyboard keys.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 60
3 comentários
Where's the picture? Adicionar imagens a uma pergunta já existente
por Dan
Can you give a better description than "blue Stuff"? Are you doing this jumping all over or it doing it on its own? Have you spilled anything on the keyboard?
por mayer
@mayer .
it is doing it on its own and i did not spill anything on the keyboard. cannot even deduce what could be wrong.
por Ayobola Biola Ayowole-Obi
