Flex cable connector overheats after changing battery
After changing the battery I had the same problem. I change the cable and the trackpad it gives nothing. What is surprising is that when I disconnect the battery and I went on sector directly it works. Any ideas? Thanks
Esta é uma boa pergunta?
Can you explain more fully what you did and why as well as what is the issue now.
por Dan
Hi Dan, thank you for your return.
Initially I had a battery problem that does not recharge, but I continued to use my Mac with MagSafe 2 Charger six months later. This week I bought a new battery and I changed it by following a tutorial successfully and at the moment I turn on the mac the trackpad and the keyboard are blocked. I thought first cable flex so I changed without success, then the trackpad but no result! after several searches I discovered that when I turn on the laptop the flex cable connector located on the motherboard overheating.
por aurban92
