oxygen sensor not communicatng
oxygen sensor not communicating code p140
Esta é uma boa pergunta?
Thoroughly examine the wiring harness to the oxygen sensor connector and then the wires to the sensor for cuts, breaks, abrasions, rubbing, etc. and fix where appropriate. Also examine inside the oxygen sensor connector to make sure the pins are there and are not dirty/corroded. If this does not fix the engine code or there are no issues with the wire harness, I would replace the oxygen sensor. I don’t think they are overly expensive for your vehicle. $20-$80 on rockauto.com.
Esta resposta foi útil?
thank you, i will try this, and let you know, thaks again
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 35
