Can’t unlock iPhone despite putting correct passcode
Hello,
I recently replaced the screen on an iPhone 6 that was having touch issues. I was able to replace it just fine and worked perfectly except that I lost Touch ID functionality despite using the original home button and flex cable (I verified to make sure that the cable wasn’t damaged or anything). The following morning I was able to get on it and then after a while, I tried to get on it using the same passcode and it will not let me in. Interestingly enough, I kept trying and trying and the iPhone won’t disable its self as it normally would after a few incorrect tries. I have tried putting the device in DFU and Recovery mode but it will not work, it’s as if the home button does not completely work. Also, the home button does turn on the screen when the device is asleep, I have to press the side button for it to turn on and then I can use it. iTunes will not recognize it because I need to unlock it for it to trust my computer. I have tried different software but had no success. This is a friend’s device that I need to get repaired as soon as possible.
Any suggestions?
Thanks!
Esta é uma boa pergunta?
