My SD card won't stay in!
My SD card doesn’t go in all the way and it won’t stay in. How can I replace the SD card slot?
Esta é uma boa pergunta?
@Chancei White If you have done a visual inspection and there is no obvious debris inside the slot, then opening up the camera is probably required to either do visual inspection of the holder, damage to the locking mechanism or replacement of the the sd holder. You can get an idea of what is involved by looking at the tutorials (they are non specific to your particular problem though) at:
FWIW, the following site which sells a new SD holder and of which I have no affliation nor am I promoting said site) recommends professional installation:
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 1,111
2 comentários
SD card lock tab maybe source of the problem? Have you checked?
por prop man
@propman Yes, I have. I’ve even tried other SD cards to make sure it’s not just mine.
por Chancei White
