Ir para o conteúdo principal
Truck won't start after driving
I can start the truck and drive for several hours . Get home turn it off let sit for several hours try to start it but just continue to turn over but won't start. I don't think fuel is dumping from the injectors but I can hear the fuel pump
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hey, Daryl. The first thing I suggest is checking for spark. You can obtain an inexpensive tester at an auto parts store, or make your own with an old spark plug. Once you can say whether or not the spark plugs are firing I would check for fuel. Get a can of starter fluid from the parts store, remove the air cleaner assembly and spray a little bit into the throttle body. If it starts up and runs for a moment before dying, you likely have a fuel issue. Let me know how these first tests go and I’ll guide you from there. Good luck with your repairs!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Daryl será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 33
