usb dissconnect high power device
SONY BRAVIA KD55EX7073SU
Keeps showing High power device please disconnect USB showing bottom right even with nothing at all connected at all
Esta é uma boa pergunta?
weird, in case you haven’t disconnect the power and press the power button on the right back (if it’s like mine) to make sure it’s drained and plug back in. you could also try cleaning the USB port with something wood or plastic such as a tooth pick, and also update the firmware which can be done via wifi I think around the device info or support section in the settings.
Esta resposta foi útil?
Tried all that no change tv still the same thanks
Wait for some several minutes then press home button or ok button to solve it ……thanks me later ?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 8,833
Sony LED TV high power device please disconnect
por Vishnu
Sony LED TV high power device please disconnect USB
por Vishnu
My Sony Led modal no KLV28R412B IS PROBLEM SCREEN SO HIGH POWER DEVICE PLEASE DISCONNECT USB
por SUNIL KUMAR
Sony Bravia showing high power device please disconnect usb but no usb connected
por Vinay Dongre
I have just bought led strip lights for my Sony bravia TV. TV keeps saying
High powered device. Please disconnect USB.
Is there any way to stop this pop up on screen as its to big and distracting.
por Peter Spanner
Exibir mais 2 comentários
