MacBook Pro 2017 not coming up after not being used for sometime
Hello,
I have left my MacBook Pro for more than a month now without using it. Now when I try to power it up, it won’t come up. Any advice on what to do or what the issue might be?
EDIT:
Here is the screenshot after installing CoconutBattery. Does it seem that there is any issue with my battery?
Esta é uma boa pergunta?
3 comentários
Can you tell us what is your exact model 13" or 15"?
por Dan
It's a 13-inch Macbook Pro
por gideon onwuka
Well, the good news the battery is still OK! But you are running your system hard! You have quite a few cycles for such a young system. You should get into the habit of not letting the battery run down so far before charging. When you run down below 30% you will likely push a cycle which will add up to the point you'll need a new battery.
I'm wondering if one of your ports is damaged which is why you had a problem charging the system before. I think it would make sense getting the power meter to check if you have a bad port. As it turns out the port assembly is easy to replace.
por Dan
