Ir para o conteúdo principal
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
My beautiful monitor, in pieces, hinge froze, removed, cannot get back
Hinge froze, disassembled monitor with new hinge in hand, possibly a part that has NEVER, EVER been documented! Wasn’t there a recall????
New hinge placed where the old one was, I can snake around all the little cords, but do I have the hinge……right? and how the !&&* to snake the base in and ‘set’ properly on ?? funtimes……
The backfill; Monitor would not come back up after disconnected from power. pple started a process to replace/repair it and then I got a cancer diagnosis, 5 years later after a divorce move and an asset sale, I took the VESA adaptor off and the hinge promply slapped back inside the monitor. I started the process to fix it, gothere, got a hinge and played with said hinge on the base for awhile and found it’s best alignment, put the hinge into the display backwards to force more of the hinge out the back of the monitor. Attached display and BOOM it came up ;) . Still shi*scared to unplug it, I mean it’s always come back after being ‘off current’ for at least 3 days. but I’m familiar with the guts now that I could replace any of the boards inside.
After working with it a few times over the weekend.
The best, most readable display I’ve EVER sat in front of. I could NOT ask Apple to repair, even though the delay wasn’t my choice or fault, they shouldn’t bleed after that long!
Esta é uma boa pergunta?
Pontuação 0
2 comentários
How about more details on what the exact issue is, maybe a pic or two Adicionar imagens a uma pergunta já existente
por
Happy it all worked out
por
Adicionar um comentário
1 resposta
Solução escolhida
I think I get the gist what you are having problems with. Reading your question sideways and with a mirror ;-}
The question is how do I attach the foot to the hinge - Correct??
There is a spring catch that you needed to push aside to gain access to the screws to take the foot off. You need to reverse this same approach to lower the hinge plate down to then gain access to the tang to screw the foot back on.
Watch this to see how you need to release the catch Apple IMac VESA Mount Adapter Install Tutorial
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
michael Davis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 115
