Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Touch id sometimes stops working after screen replacement
Hello, so i’ve replaced the screen of my iphone 6s and transfered the original home button. Everything went fine, i had set up touch id and was succesfully using it, until next day the phone stopped picking up my fingerprint. I then tried rebooting the device, soft reset, hard reset, but nothing helped. I figured it must be hardware related, so opened up the phone , disconected and then reatached the home button, turned the phone on while it was opened and the touch id was working again. So then i put all the metal plates again, screw in all the screws in, basically seal the phone again, and the touch id stops working again. I assume the ribbon cables aren’t broken, because i could set up the touch id, and it’s also not software, because i erased the phone multiple times, have the latest ios installed. Anyone faced anything like this before? Any ideas on how to fix this?
Update (10/23/2019)
Turns out, all of the screens i bought from china were defected in some ways, and none of them supported touch id
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
1 Resposta
Solução escolhida
When you restart the phone does it come up as a notification that Touch-ID is not working?
And have you tried with the old screen if touch-ID works?
Could be the new screen that has a faulty flex cable for home button.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Matt101 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 24
