Ir para o conteúdo principal
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 Perguntas Visualizar todos
battery not charging after battery replacement
I replaced the battery in my early 2015 retina macbook using the ifixit kit. Everything went fine and the device powered up after repair. The battery charged completely overnight and I fully discharged it the next day as in the instructions. Couple days later, the battery won’t charge and shows “Battery is Not Charging” in the battery dropdown. The battery is recognized by the computer and it shows 2 cycles, good battery health, etc… But it isn’t being charged by usbC. I’ve tried 2 different chargers, btw. Also tried SMC reset several times.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Try PRAM reset, reseating the battery, new charger. If all else fails, send the battery back to where you purchased it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Zach H será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 83
