Ir para o conteúdo principal
How do I unplug these connectors?
Hi, very basic question, how do I disconnect these? There's no obvious catch or latch but they're also definitely not unplugging without some kind of release and I need to solder the charging port back on to the board, which I can't access comfortably without unplugging the cables. Thanks in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try googling Molex connectors, click on images and see if any are similar to what you have.
On the top connector, is that a clip lock on the side facing the camera?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Shannon Ryan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 42
