Ir para o conteúdo principal
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
639 Perguntas Visualizar todos
My iMac is stuck on a question mark
After installing a new SSD I’m stuck on the question mark and unable to boot up.
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Here's a reference to the startup key combos Mac startup key combinations
por
Adicionar um comentário
2 respostas
Pergunta Mais Útil
Try to hold [alt] while you start the imac and you should see your system. If that was the Problem: Boot it up and go to the System Preferences->Startup Disk and choose your system as the Startup Disk.
Esta resposta foi útil?
Pontuação 1
Comentários:
@spaeder - The Apple keyboards are marked Option (⌥) as the primary marking.
por
If Spaeder’s answer does not work your drive likely has become corrupted or has failed. Try Command (⌘) and R keys to see if you can recover your OS, if you can’t you’ll need to get a new drive.
Pontuação 1
Adicionar a sua resposta
Jay será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 37
